Vuurtoren nlicht
Gestart door argilla, 27 april 2013, 18:54:21 PM
argilla
Kan er iemand aub meer uitleg geven over dit onderwerp ? Volgens mij gaat het over een soort van knipperlicht voor in een vuurtoren. Maar wat voor onderdelen men gebruikt en hoe ? ?  :(
Komt uit garden railways magazine engelstalig. Wat is een Picaxe ?
http://grw.trains.com/Product%20and%20Hobby%20News/Product%20Videos/2013/02/Build%20a%20lighthouse%20beacon%20or%20Mars%20light.aspx
Build a lighthouse beacon or Mars light Cut and paste code for a Mars light and more
By David Bodnar Published: February 22, 2013
picaxeThe flashing lighthouse beacon is controlled by a inexpensive microcontroller called a Picaxe. Photo by David BodnarIn the April 2013 issue, David Bodnar explains how to use and program a Picaxe to make a lighthouse beacon or Mars light. Cut and paste the code here to save time on your project!
Program 1#Picaxe 08M2 'tell the program which chip we have
Top: 'label to indicated the top of the program
HIGH 2 'light the LED on output #2, pin 5
PAUSE 500 'pause for 1/2 second (500/1000 sec)
LOW 2 'turn off the LED
PAUSE 500 'pause again
GOTO Top: 'go back to the label "Top:"
Click on the "Syntax" button at the top of the editor.
If you have entered the program correctly you will get a report of success and the number of bytes of memory that were used and those remaining.
Lighthouse-beacon program#NO_DATA 'speeds up programming
#Picaxe 08M2 'identify the chip
SETFREQ m32 'speed it up to 32 MHz
SYMBOL Loopie = b2 'label variable b2 as Loopie
SYMBOL Brightness = b1 'label b1 as Brightness
SYMBOL Dlay = 150 'set constant Dlay to 150
Start:
For Loopie = 0 to 100 step 1 '100 steps from off to bright
brightness=255-loopie
pwmout c.2, brightness, loopie 'use PWM to brighten the LED
pause Dlay 'pause a bit
next loopie 'get the next item in for/next
pwmout c.2, 255,1023:pause 1000 'flash to full bright briefly
for loopie = 100 to 0 step -1 'repeat above backwards
pwmout c.2, brightness,loopie
pause Dlay
next loopie
pause 2000 'pause a bit with LED off
goto start 'do it again!
Mars light program#NO_DATA 'speeds up programming
SYMBOL Dlay = 2 'set constant Dlay to 2
Start:
Gosub ShortFlash 'do the shorter flash routine
Gosub LongFlash 'do the longer flash routine
GOTO Start: 'repeat
ShortFlash: 'a label
pwmout c.2, brightness, loopie 'light the LED
pause Dlay
next loopie
sertxd (#loopie, " ")
pause Dlay
next loopie
return 'return to the point where the routine was called
LongFlash: 'do the longer flash
For Loopie = 0 to 255 step 1 '255 steps from off to bright
pause Dlay
next loopie
for loopie = 255 to 0 step -1 'repeat above backwards
pause Dlay
next loopie
return
Morse-code programSYMBOL Deelay = 500
SYMBOL dittime = b4
SYMBOL LED = c.2 'Pin 5
dittime = 100
EEPROM 0, (" welcome de n3enm pittsburgh !") 'message must be lower case - numbers OK - ! to end
Start:
for b1=0 to 255
read b1,b2
sertxd (b2," ")',#b2)
if b2="!" then SkipOut: 'finished with text - stop sending
if b2>= "0" and b2<="9" then 'if it is a numeral adjust
b2=b2 -48+26
goto SkipHere:
endif
if b2=" " then 'if a space adjust
sertxd ("space",13,10)
pause Deelay' space to pause between words
goto Skipover:
endif
b2=b2-97 'decrease ASCII value for "a" to 0, "b" to 1, etc
SkipHere:
on b2 gosub aa,bb,cc,dd,ee,ff,gg,hh,ii,jj,kk,ll,mm,nn,oo,pp,qq,rr,ss,tt,uu,vv,ww,xx,yy,zz,n0,n1,n2,n3,n4,n5,n6,n7,n8,n9
Skipover:
pause Deelay
next b1
SkipOut:
goto Start:
aa:gosub dit:gosub dah:return
bb:gosub dah:gosub dit:gosub dit:gosub dit:return
cc:gosub dah:gosub dit:gosub dah:gosub dit:return
dd:gosub dah:gosub dit:gosub dit:return
ee:gosub dit:return
ff:gosub dit:gosub dit:gosub dah:gosub dit:return
gg:gosub dah:gosub dah:gosub dit:return
hh:gosub dit:gosub dit:gosub dit:gosub dit:return
ii:gosub dit:gosub dit:return
jj:gosub dit:gosub dah:gosub dah:gosub dah:return
kk:gosub dah:gosub dit:gosub dah:return
ll:gosub dit:gosub dah:gosub dit:gosub dit:return
mm:gosub dah:gosub dah:return
nn:gosub dah:gosub dit:return
oo:gosub dah:gosub dah:gosub dah:return
pp:gosub dit:gosub dah:gosub dah:gosub dit:return
qq:gosub dah:gosub dah:gosub dit:gosub dah:return
rr:gosub dit:gosub dah:gosub dit:return
ss:gosub dit:gosub dit:gosub dit:return
tt:gosub dah:return
uu:gosub dit:gosub dit:gosub dah:return
vv:gosub dit:gosub dit:gosub dit:gosub dah:return
ww:gosub dit:gosub dah:gosub dah:return
xx:gosub dah:gosub dit:gosub dit:gosub dah:return
yy:gosub dah:gosub dit:gosub dah:gosub dah:return
zz:gosub dah:gosub dah:gosub dit:gosub dit:return
n0:gosub dah:gosub dah:gosub dah:gosub dah:gosub dah:return
n1:gosub dit:gosub dah:gosub dah:gosub dah:gosub dah:return
n2:gosub dit:gosub dit:gosub dah:gosub dah:gosub dah:return
n3:gosub dit:gosub dit:gosub dit:gosub dah:gosub dah:return
n4:gosub dit:gosub dit:gosub dit:gosub dit:gosub dah:return
n5:gosub dit:gosub dit:gosub dit:gosub dit:gosub dit:return
n6:gosub dah:gosub dit:gosub dit:gosub dit:gosub dit:return
n7:gosub dah:gosub dah:gosub dit:gosub dit:gosub dit:return
n8:gosub dah:gosub dah:gosub dah:gosub dit:gosub dit:return
n9:gosub dah:gosub dah:gosub dah:gosub dah:gosub dit:return
dit:
sertxd (".")
high LED
pause dittime
low LED
pause dittime
return
dah:
sertxd ("-")
high LED
pause dittime :pause dittime:pause dittime
low LED
pause dittime
return
argilla
H0, On30, 1/29, Gn15
bijna zeker een µC programma, maar niet commercieel...
Citaat van: argilla op 27 april 2013, 18:54:21 PM
Wat is een Picaxe ?
Dat staat in de tekst die je zelf laat zien. Het is een microcontroller.
Met google vind je er ook veel informatie over.
oebr
Picaxe is een producent van eenvoudige pic-processortjes. Het interessante eraan is dat je ze (zogezegd) in een heel eenvoudige programmeertaal (een of andere variant van Basic) kan opdrachten geven. De meeste pic's vragen (al dan niet beperkte) kennis van bvb assembler of een of andere C-variant.
Nu dat basic simpeler is dan assembler ga ik zeker niet tegenspreken, maar of je beter af bent met Basic dan met C is een twijfelgeval.
Een Basic programma gaat uit van een aantal lijnen met code die uitgevoerd moet worden (of net niet - al naargelang de voorwaarden) en van procedures (stukjes programma bestaande uit een aantal lijnen) die elders in de lijst van lijnen staan en waar de processor heen kan springen indien nodig. In Talen zoals C ga je die stukjes aparte code veeleer in andere programma's of in vooraf beschreven functies onderbrengen.
Dat laatste levert meer werk voor het vertaalprogramma dat die externe of semi-externe codes in de hoofdcode moet onderbrengen en die compositie moet omzetten naar uitvoerbare code die in de chip gebrand wordt om dingen te laten gebeuren. Maar voor de programmeur is het wel iets makkelijker werken indien het programma redelijk groot wordt.
Maar voor een vuurtoren lichtje zal die basic benadering effectief toch wat simpeler zijn.
Ik gebruik voor mijn microcontrollers Bascom. Dat is een vertaalprogramma dat een Basic-achtige taal omzet in machinetaal (voor AVR µC's).
Dat doet die vertaler best wel compact. Ik krijg behoorlijk complexe programma's in weinig programmageheugen.
Zo'n Basic-programmatekst is een stuk compacter, leest en debugt dus vrij gemakkelijk.
Indien nodig kan je nog assembler toevoegen, maar dat heb ik tot nu toe nog niet nodig gehad.
