Peco track
Gestart door Dirk, 04 februari 2017, 15:59:16 PM
philippe_007
overlaatst een grote bestelling gedaan bij hattons, heel tevreden ivm prijs en service....
de wisselkoers £ - € stond toen wel ideaal.
SirGresley
Volgens de Engelse modelspoorders is Peco te H0 omdat voor OO de bielzen te kort bij elkaar liggen.
Wikipedia hierover:
CiteerOO describes models with a scale of 4 mm = 1 foot (1:76) running on HO scale 1:87 (3.5 mm = 1 foot) track (16.5 mm/0.650"). This combination came about as early clockwork mechanisms and electric motors were difficult to fit within H0 scale models of British prototypes which are smaller than equivalent European and US locomotives. A quick and cheap solution was to enlarge the scale of the model to 4 mm to the foot but keep the 3.5 mm to the foot gauge track. This also allowed more space to model the external valve gear. The resulting HO track gauge of 16.5 mm represents 4 feet 1.5 inches at 4 mm to the foot scale, this is 7 inches under scale or is approximately 2.33 mm too narrow.
Citeer16.5 mm (0.65 in) gauge at 4 mm:1-foot means that the scale gauge represents 4 ft 1 1⁄2 in (1,257 mm), 7 inches (178 mm) narrower than the prototype 4 ft 8 1⁄2 in (1,435 mm). This difference is particularly noticeable when looking along the track. As the market for proprietary track is mostly for HO scale, sleeper size and spacing are designed for HO and are therefore underscale.
OO is also used to represent the 5 ft 3 in (1,600 mm) Irish gauge, where it is a scale 13 1⁄2 inches (343 mm) too narrow.
Though they run on the same track, OO gauge and HO gauge models of the same prototype do not sit well together since the OO models are larger than the HO equivalent.
These differences have led to the development of the finescale standards of EM gauge and P4 standards. Nevertheless, it is possible to model using OO to standards that fall just short of finescale.
Persoonlijk rijd ik op code 100 omdat daar de meeste wielen geen last meehebben. Ik ben geen muggenzifter en zeggen dat die rail te hoog is maar laat maar eens een ouder rijtuig op code 75 rijden!! :P
De keuze in wissels en dergelijke is voor hetzelfde.
Ik volg de redenering van SirGresley , maar dat moet ieder voor zichzelf uitmaken natuurlijk. Heel tevreden over mijn rail-keuze.  ;)
Citaat van: SirGresley op 09 februari 2017, 14:40:18 PM
Ik heb moeite moeten doen om in mijn collectie een wagen te vinden met te hoge flenzen, en ik ben toch al sinds 1960 met modelspoor bezig. Je kan er ook voor kiezen om er andere wielstellen in te steken.
patrick smout
Hallo Dirk ,
heel goede ervaring met EHattons
Patrick Smout
Met vriendelijke groeten,
Patrick Smout
Svendw
Rij ook peco code 100, en besteld bij ehattons. Je hebt het binnen de 5 werkdagen na betaling normaal gewoon binnen..
Ho NMBS tijdperk V en VI met uitschieters in DC 2rail - ESU ecos2 - Koploper.
The Book Of Souls World Tour freak 😎
Ehattons =goede service, snel en correcte prijs :)
Waterman
Ik heb nog een paar oude Lima locomotieven en treinstellen, kunnen die ook ongehinderd over code 83 (of zelfs code 75) rijden? Of ga ik dan de wieltjes moeten aanpassen?
Dat hangt er van af hoe oud ze echt zijn. Het eenvoudigste is om het eens te testen ...
Waterman
Citaat van: Gerolf op 16 februari 2017, 10:38:36 AM
Mijn NMBS reeks 15 komt regelrecht uit de jaren '70, en bij mijn Transalpin zal dat niet veel schelen denk ik.
Heeft er iemand een baan met code 83/75 rails waarop ik eens mag komen testen  ;D
83 heb ik ;)
... maar je kan ook eens kijken bij de MOROP-normen, en je flenshoogte meten  ;)
Waterman
Citaat van: Gerolf op 16 februari 2017, 11:23:33 AM
83 heb ik ;)
En waar woon jij?  ;D
Zo eenvoudig dat ik er zelf nog niet op gekomen was! Ik ga daar maar eens mee beginnen  :)
Maar gewoon uit nieuwsgierigheid: als je wielflenzen te hoog zijn, wat kan je dan doen? Andere assen steken lijkt mij eenvoudig bij wagons en andere niet aangedreven assen, maar bij de aangedreven assen van een locomotief of treinstel is dat toch al niet meer zo eenvoudig? Of kan je de wielflenzen laten afdraaien met een draaibank?
Vervangasjes/-wielen vond men bij enkele handelaars op de voorbije MSM-tentoonstelling te Leuven.
Er zijn verschillen in verkoopprijzen...
Let op:  verschillende wieldiameters  &  flensen en diverse lengtes van de asjes van-punt-naar-punt.
Bij  tijdperk3-H0-goederenwagens  is het leuk meegenomen van nieuwe spaakwieltjes (met bescheidener flens) te monteren in plaats van de oudere volle wielen met te forse flens.
Er zweeft hier ergens op het MSM-forum een rubriekje over dit specifiek onderwerp .
Citaat van: Waterman op 16 februari 2017, 10:57:28 AM
Ik heb ook een baan met code 83 rails.
Waterman
Citaat van: Herwig op 16 februari 2017, 13:29:01 PM
Maar je hebt het hier weer over de assen van wagons, terwijl ik vooral een probleem zie bij het vervangen van aangedreven assen van locomotieven en treinstellen.
Citaat van: OlivierV op 16 februari 2017, 22:09:31 PM
En jij woont gelukkig al iets dichterbij  :D
