ESU LokProgrammer software update
Gestart door eve, 27 januari 2015, 09:28:21 AM
ceuleer
Nieuwe versie 5.0.4 staat op de site van ESU.
Version 5.0.4:
- Bugfixes:
  * Soundeditor - Volume min/max and pitch range min/max can not be changed when the text box is empty.
                - Soundtype(single-channel) -> in a trigger condition, a mode other than immediate can be selected.
  * LokSound 5 family - Compiler -> state without sample is occasionally left too early.
- New firmware version 5.0.67 for LokSound 5 family / Essential Sound Unit:
  * Soundslot 1 and Soundslot 2 determine if driving sound is on for random sound.
  * DCC decoder - Speed table -> additional "Use three values".
ceuleer
Nieuwe versie 5.0.5 staat op de site van ESU.
Version 5.0.5:
- Bugfixes:
  * Sound simulator - incorrect playback of state transitions immediate / cross.
  * Sound - add sound files -> volume is partially changed.
  * LokSound 5 family - new firmware version 5.0.68 -> constant brake distance on speed step 0 (CV27.7).
                      - new firmware version 5.0.71 -> CV23 and CV24 incorrect acceleration time / brake time adjustment.
                      - read decoder data into the current project
                        -> brightness values (function outputs) ​​are not correctly adopted in some places.
- Information:
  * Locomotive description - height of input field increased.
- Bulletin:
  * show decoder type.
- New firmware version 5.0.70 for LokSound 5 family:
  * Physical output configuration - new output mode -> Servo Power.
