Auteur Topic: ECOS centrale  (gelezen 6084 keer)
  • Gast
Re: ECOS centrale
« Reactie #15 Gepost op: 30 september 2015, 10:40:17 am »
Was even zoeken; je moet inderdaad inloggen, het is dus inderdaad voor de kleurenscherm-ecos
(ik val hier in herhaling Niels :D )
De computer-interface is verbeterd; ik moet het ellenlange txt file nog doorworstelen.
  • Gast
Re: ECOS centrale
« Reactie #16 Gepost op: 30 september 2015, 10:45:13 am »
Als ik nu nog wist hoe je die firmware weer moest updaten.... ::)
Offline Ludwig
  • Voornaam: ludwig
Re: ECOS centrale
« Reactie #17 Gepost op: 30 september 2015, 16:19:42 pm »
En wat is er nieuw in deze update ?
Ludwig
3 rail k rails, Ecos 2
  • Gast
Re: ECOS centrale
« Reactie #18 Gepost op: 30 september 2015, 17:53:19 pm »
Lees het txt file! Te veel om op te noemen. Maar vooral de PC-interactie is verbeterd. Programmeren via de PC bv.
Offline ceuleer
  • Voornaam: gunter
Re: ECOS centrale
« Reactie #19 Gepost op: 01 oktober 2015, 00:00:21 am »
Hier de 4-1-0 Release Notes.
Release Notes for Software 4.1.0 for ECoS 50200 / ECoS 50000 / Central Station Reloaded
 Main target of this firmware version was to improve the computer interface.
 Now a computer software can access the ECoS' programming track.
 Further peformance problems and crashes under heavy load should be eliminated. Last,
 but not least we changed the consist mode behaviour of the ECoS.
 Release notes:
 Features:Modified behaviour for consists.
 Now, you can select any locomotive that is in a consist and control the speed of all locomotives that belong to the consist.
 Further, you can control the function buttons of each locomotive that is in a consist individually.
 The traction itself shows the functions of the first locomotive only and can change these, too.
 In the web interface you can now see the position and the trigger conditions of routes
 New decoder profiles for new hardware revisions of LokSound decoders.
 ECoS is now equipped with a DHCP-Server. This can provide IP-addresses for clients.
 Do not use if another DHCP-Server is in your network already!.
 A configuration setup menu for the ESU Mini Accesspoint is enabled, too.
 PC-Interface 2.0 (see below).
 Bugfixes:
 Sometimes, F8-F12 could sometimes not be disabled / enabled.
 It is no longer possible to create invalid consists.
 "No control" is handled properly now and will be displayed on the throttle
 Address conflicts will be handled correctly now and showed in the throttle
 Locomotives that are used in consists will show a symbol in the throttle now
 Several crashes with Three- or four-aspect accessories are fixed now.
 Selectrix programming on the programming track now writes correct values.
 Editing routes now disables the automatic switching of a route and does no longer trigger other routes
 When creating track feedback icons in the track diagram, the system crashed sometimes when there was no real ECoSDetector attached.
 Some problems with placing address feedback symbols in the track diagram are fixed.
 Some charset problems in combination with feedback module's names are fixed.
 Fixed multiple update/redraw bugs in the GUI
 The log event window will be updated now.
 ECoS crashed sometimes on connection lost between PC software and ECoS.
 Hotkey to Reset the internal settings now works again.
 The Java-Applet to show the screen content in the webbrowser shall now work using Java8, too.
 PC-Interface 2.0:
 The PC Interface is completely recoded and we hope it performs much better now.
 There are just a few minor changes in the specification (only when absolutely neccessary or obviously wrong in the past).
 Most PC software / Apps should therefore work as before whithout any problem.
 However, some problems showed compatibility issues, therefore we added an additional menu to Setup 3 to configure the PC interface.
 Enable warnings should be used only while developing. If enabled, the ECoS will send additional return commands and hints to show you
 wrong usage of the interface. Especially TouchCab does not like these warnings.
 For Koploper and ControlGUI you need to enable the "Legacy-Mode". Then the ECoS performs as previous software versions.
 Here is some highlights of the new PC interface implementation:
 New buffer handling: Now, more memory is temporarily available. Performance bottlenecks should be eliminated now.
 The parser is more strict now. Wrong syntax will not be accepted any longer.
 The error messages are more comprehensive now, too.
 Using Setup 3, you can now opt for error messages of the PC interface to be written into the ECoS event log.
 ECoS can now enable a watchdog for PC connections on object 1. Optional, a Stop could be triggered on timeout.
 See help(1,set,watchdog) for details.
 Using object 1, you can now query a blinking go-key (status2), M4 detection (m4-status),
 RailComPlus detection (railcomplus-status) and the programming status (prog-status).
 Further, new detected locomotives can be taken over. In addition, events could be stored in the ECoS-log (writelog).
 The Icon shown when accessories are thrown (two arrows) are now also available in the PC interface.
 When creating a view, using the update option you can now get the current values, so that you don't need the get any longer.
 Using the option updateonerror , you can globally define that (some) failed set commands return the current values automatically.
 Get can be used in a more common way now. get(100,func) for example now returns all existing functions while get(1000) returns
 all implemented attributes.
 Now, views on manager objects will return information about the changed items. You will also see which objects are changed.
 Using manager objects, request(10,view,listattribute[addr]) will return updates of changed attributes of the objects managed
 by the manager object.
 Using the attribute option, you can restrict the view to one object.
 There is a simple implementation (read-only, now update events) of the turnout control manager. get(31,link[0]) will return
 the content of the first page of the turnout control panel for example.
 Access to the ECoS programming track. Please note: You need a view on the programming track, because the data will be returned
 in an update event. At this moment, we implemented DCC direct mode read/write and Motorola 6021 write.
 For example: request(5,view) set(5,mode[readdccdirect],cv[1],cv[2]).
 Please note that you  shall use set instead of get, even when reading Cvs. Further information shows help(5,set,all).
 Further information about the specification can be found using telnet Port 15471 and help() for the online help system.
Wat ik interessant vind aan deze update, de Ecos 2 zou terug op het PC scherm te bedienen zijn.
Offline ceuleer
  • Voornaam: gunter
Re: ECOS centrale
« Reactie #20 Gepost op: 06 oktober 2015, 21:46:27 pm »
Zopas de update 4-1-0 geïnstalleerd, de Ecos 2 is dus terug te bedienen via "display in browser", in Firefox en Internet Explorer.
In Google Chrome werkt het niet, "deze plug-in wordt niet ondersteund" komt er op het scherm.
Maar geen probleem, de 2 andere browsers doen het dus terug.
Ook werken de functie toetsen F8 en F9 bij alle decoders terug, deze functies werkten wel op de lokprogrammer, maar op de ecos werkten ze voor de update niet.
Volgens de handleiding zou het over de functies F8 t/m F12 gaan, die nu terug werken.
Dit probleem deed zich niet bij elke decoder voor, maar nu werken de functies allemaal perfect.  ;)
grz,
Gunter
  • Gast
Re: ECOS centrale
« Reactie #21 Gepost op: 07 oktober 2015, 14:36:02 pm »
Voor alle zekerheid: kan iemand nog eens de juiste werkwijze voor het updaten zeggen?
Is gelukt!
Offline ceuleer
  • Voornaam: gunter
Re: ECOS centrale
« Reactie #22 Gepost op: 07 oktober 2015, 15:26:45 pm »
De ecos aanzetten en met de modem verbinden via de netwerkkabel.
Op de pc via firefox (of andere browsers) de ecos zoeken door het ip adres in te geven in de url, op enter klikken en de ecos pagina zou op het scherm moeten verschijnen. Je kan Duits of Engels kiezen.
Het ip adres staat op de ecos onder het icoon bovenaan met de steeksleutel, erop klikken, in tabblad "instellingen 1" staat er links onderaan het icoon met IP, klik erop en hier vind je uw ip adres.
Dit geef je in uw browser in.
De update is een zip bestand dat je moet unzippen, dus uitpakken, door op de muis rechts te klikken en "hier uitpakken" te selecteren.
Dit bestand ga je via de ecos pagina in firefox zoeken en installeren.
Kilik op "firmware update" en dan op "bestand kiezen", zoek het uitgepakte bestand op de pc, selecteer dit bestand en druk dan op "send".
Nu gaat hij updaten.
Misschien voor de update eerst een backup van uw ecos maken via "store configuration", klik op "store settings" en selecteer een map op de pc waar je de backup wil wegschrijven.
Als je dit eerst doet, kan je de backup terug op de ecos zetten als er iets misloopt via "restore configuration"
Ook wanneer de nieuwe update goed geinstalleerd is, kan je best een backup van de nieuwe instellingen maken, bij problemen heb je altijd een backup met de laatste aanpassingen van de ecos.
Voila, hier ben je al wel een tijdje mee zoet, een backup maken duurt maar enkele minuten, dus zeker doen, een update duurt iets langer.
Wanneer je een update doet of een backup maakt kan het zijn dat het pc scherm enkele seconden niet reageert, dus een beetje geduld wanneer je op iets geklikt hebt  :)
Offline jakke
  • Voornaam: Jan
Re: ECOS centrale
« Reactie #23 Gepost op: 07 oktober 2015, 15:44:41 pm »
De ecos aanzetten
Dank voor de heldere uiteenzetting .
Een goei geheugensteuntje .
Offline ceuleer
  • Voornaam: gunter
Re: ECOS centrale
« Reactie #24 Gepost op: 07 oktober 2015, 15:47:34 pm »
Graag gedaan.  ;)
Offline Doornroosje
  • Voornaam: Dennis
Re: ECOS centrale
« Reactie #25 Gepost op: 26 april 2016, 11:57:02 am »
Even toch nog een oud topic openen. Ik heb een ecos2 centrale en wou deze zoals hierboven updaten. Alles ging goed, enkel update hij niet. Hij geeft na enkele seconden aan "update not succesfull". Iemand ideëen wat er mis zou kunnen zijn? De file heb ik verschillende keren afgehaald, dus die is niet corrupt. Het esu scherm komt op de pc op als ik het ip adres ingeef, dus de verbinding is ook ok. Nu staat de centrale op firmware 3.1.1 en de update is 4.1.7. Moet ik misschien in tussenstappen updaten, gaat het niet in 1 keer?
Offline bellejt
  • Graag een glaasje wijn
    • http://www.johnnyrail.net
  • Voornaam: Johnny
Re: ECOS centrale
« Reactie #26 Gepost op: 26 april 2016, 12:12:38 pm »
je moet een tussenstap maken met 4.0 .Lees eerst goed oor hoe het moet want als deze misgaat moet je de ecos naar hun opsturen.Ga voor je ff zoeken naar de uitleg en meld me dan terug
Offline pandur
  • Voornaam: Eric
Re: ECOS centrale
« Reactie #27 Gepost op: 26 april 2016, 12:13:16 pm »
Dennis,
Uiteraard moet je de tussenstappen eerst uitvoeren,
Let wel op de versie 50200 (kleur) of 50000 (zwart/wit)
Al de tussenstappen zoals aangegeven op de site van ESU zijn vervolgens uit te voeren,
Opgelet met de overgang naar sw 4.0.0 deze moet in twee keer genomen worden
succes,  Eric
NMBS-DB / H0 2rail DCC / ECoS II 4.2.3 / ECo Boost /MC II / LokPro 4.7.1 (2.7.9)
Hoeseltse Trein Club / HLT
Offline bellejt
  • Voornaam: Johnny
Re: ECOS centrale
« Reactie #28 Gepost op: 26 april 2016, 12:15:31 pm »
Offline pandur
  • Voornaam: Eric
Re: ECOS centrale
« Reactie #29 Gepost op: 10 mei 2017, 17:27:34 pm »
Nieuwe software 4.2.0. beschikbaar voor ECoS
opgelet je moet ingelogd zijn
http://www.esu.eu/download/software/ecos-firmware/
Eric
